$$$ WD45 Engine $$$$$
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: $$$ WD45 Engine $$$$$
    Posted: 24 Apr 2010 at 7:22pm
Got another WD 45 engine back to life and it's for sale.  Had head gasket leak so that came off and while in there, lapped the valves and reset them.  New basket on oil filter base.  New points, condenser, coil, wires and plugs.  Engine starts and runs good with oil pressure around 17 when cold and 6 when warmed up.  Does not seem to smoke.  You can see and hear it run if you would want to stop by and pick it up.  It would take less than an hour to have it out of the stand and ready to load.  I'm looking for $650.00 for the engine including a fairly new manifold and muffler, water pump and fan, governor and distributor system, oil filter base, flywheel, clutch plate and pressure plate....in other words, you can pretty well drop this engine in your frame and go. Located in southern Illinois, I can also get you a shipping price if you want one. PM or email to   dennisstork@hotmail.com
Thanks, Den
Edited by den/southern illinoi - 24 Apr 2010 at 7:25pm
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 6:20pm
This is why I would like to see a buy and sell section.  Den
Dave H M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H M Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 6:43pm
yep Den your add will be buried by tomorrow morining.  My recommendation right up front was a for sale board so that stuff would b e consolidatred and readily available.
But ya know the old baord was the best and it needs to be kept from change lol.
By the way, I buzzed by your turn off there in Sparta the other day.  I just wanted to check on that little 4 WD Kabota with bush hog that has weeds growing up thru it at the Steelville Y.
take care.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 6:48pm
Still for sale.  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 7:10pm
Hey Den! Are you growing them 45 motors in your back yard or what? LOL!  Did you git' my check for the first one okay?
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2010 at 9:30pm
Steve, not growing them, just working thru a group of tractors (?) that had been in a fire and were camaged beyond saving as complete tractors.
Yes, the check did make it.  Den
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 7:01am
Den if I needed one I'd be calling you at that price.
Don
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2010 at 9:10am
<bump>
Pushing this thread back up the list, because it sounds like a beyond-excellent deal.
Wish I could get it - I have need for one for a project tractor, but the mad-money fund is shot right now.  <snif>
saladito ranch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saladito ranch Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 1:33pm
hi den,are you still have it the engine for sale??thanks
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 7:38pm
  we have various engines for sale   wd45   d-17 that are useable  1-574-342-4545
This page was generated in 0.469 seconds.
