WD-45 engine
worldchamp19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 engine
    Posted: 26 Jul 2015 at 8:37pm
I'm wanting to put a Gleaner engine in my 45 and have it bored and stoked. My question is what would work the best?
Thanks
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2015 at 8:55pm
If you're going to bore and stroke why spend the extra on a Gleaner engine and not use a regular G226? The full flow oiling is nice but not a huge gain.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2015 at 9:36pm
Ok I'll just my 45 engine, I thought Gleaner engine could be bored out more.
Shawn PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 11:12am
no it cant   its stronger tho
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 11:34am
Your engine is a W-226 if in a WD-45. The Gleaner model "E" engine is a G-226, almost identical to a D-17 tractor. The G-226 has a stronger crankshaft and block versus the W-226. You must be thinking for next Summer, right??
Post Options Post Options   Thanks (0) Thanks(0)   Quote worldchamp19 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 2:00pm
I'm going to do it soon because i have the time now and if I put it off it will be next year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 5:57pm
Well, if you find someone to weld you up a 6 inch stroke crank yet this Summer, I want his name and phone number. OK ??
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 7:32pm
hapco in terre haute IN will do it used to be $200 extra for rushing it
jfrdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfrdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2015 at 9:54pm
Is a 6" stroke even possible in a wd45 engine?
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 12:41am
Yes, you can go all the way to 6.5 and a little farther.
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfrdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 4:15pm
Is there any internal clearance issues?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 5:21pm
Certainly....tons of it. It takes different connecting rods (or custom built rods) and smaller diameter rod journals and grinding where there's interference. Sometimes the oil pan needs to be swelled up in places to allow room for the swing. Buda rods can be taken to 5.800" stroke....not sure if I'd try 6.000" or not with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jfrdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2015 at 6:43pm
Thanks, I'm new to the a/c btand and just bought a wd45 to build into a puller. I'm trying to find options for more power. I know there is a high compression 4 1/4 bore kit but not sure how much power i will gain with this alone. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shawn PA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 6:15am
That would be WD flat top pistons and maybe reach 60+ hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 7:00am
The 4 1/4" is a different kit than a 4 1/8" flat top WC/WD kit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2015 at 8:55am
I have a set of Buda diesel rods I'll sell to build a 260 if you're interested. PM me
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
This page was generated in 0.095 seconds.
