WD45 Engine Diagnosis Needed - UPDATE Nov 3 |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2400 |
Topic: WD45 Engine Diagnosis Needed - UPDATE Nov 3Posted: 25 Oct 2016 at 1:15pm |
The engine in my WD45 has run roughly since it came to live in my barn. Here's a video - fast idle initially, then at higher rpms: [TUBE]meT23XhY1NQ[/TUBE]. [Oddly, the engine sounds better in the video than in real life!]
The roughness is more noticeable at higher rpm. Perhaps related to this, there is a small amount of oil leaking at the head gasket above #1 (mostly) and #2 spark plugs. I've pulled all four plugs - there's oil in the threads of #1 and all four are a sooty color, worst at #1 and lightening toward #4. I've adjusted the high speed jet to the smoothest running spot. Carb seemed clean inside. Also checked to make sure that the choke was fully open. So maybe valve guides? Some other carb issue? Thanks for any suggestions! Dave
Edited by Dave(inMA) - 03 Nov 2016 at 5:10pm |
WC, CA, D14, WD45
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 25 Oct 2016 at 2:20pm |
I don't hear much of a problem but you may want to do a compression test to see how close all the cylinders are to each other.
1957 WD45 dad's first AC
Posted: 25 Oct 2016 at 2:22pm |
After a good compression test, throw away all those old plug wires and get real wire, not carbon core wires.
Dave(inMA)
Posted: 25 Oct 2016 at 2:41pm |
Thanks......I'll do both! Won't get to it until next week due to travel schedule.
WC, CA, D14, WD45
HD6GTOM
Posted: 25 Oct 2016 at 3:03pm |
Dave when I fires overhauled mine 30+ years ago, I couldn't wait to get it running. I put the carbon wires on it and fooled with it for a week. boys at R&M equitment told me the same thing-- throw away the carbon and go to copper.
Dave(inMA)
Posted: 25 Oct 2016 at 4:14pm |
I hope the copper wires help - honestly hadn't thought of that as a cause but it surely could be. Will report back!
WC, CA, D14, WD45
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55283 |
Posted: 25 Oct 2016 at 6:06pm |
And, Check the dist cap out, too, looks kinda old, could have some carbon tracking...
Dmpaul89
Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Posted: 25 Oct 2016 at 6:35pm |
mine runs loud too. i wear ear muffs when i use it. not talking about the exhaust either. even the gears are loud. i think thats just how they are!
Dave(inMA)
Posted: 25 Oct 2016 at 6:55pm |
Just turn down the audio and it'll run quieter!
I'll re-check the distributor cap as well, though it LOOKED okay when I was going through a few things. Might be smart to replace all that stuff given that I have no idea when they were installed in the old girl.
WC, CA, D14, WD45
WDDave
Posted: 25 Oct 2016 at 7:43pm |
My WD sounds exactly the same at idle or low load.
I was checking compression ,ignition,carb rebuilt,new intake manifold ect. but never really found a problem. When it gets under a load and the governor opens up all that goes away and it pulls strong so I quit worrying about it. |
WD ,wide front, with loader
Dave(inMA)
Posted: 25 Oct 2016 at 8:01pm |
Ah. The infamous 'no discoverable cause' outcome.
![]() Any suggestions on why there's oil on the #1 plug threads?
WC, CA, D14, WD45
Gerald J.
Posted: 25 Oct 2016 at 8:33pm |
Is it distributor or magneto? Distributor should have a working centrifugal advance so the ignition timing is retarded for idle speed and advanced for full load speed. If its stuck advanced which seems to be typical for an old engine because of springs rusted off or lack of lubrication (a few drops of oil into the felt in the hollow shaft under the distributor rotor every few months) it will knock at idle but run good at full speed. If its stuck retarded, it will run smooth at all speeds but not have anywhere near rated power at full speed and the exhaust will run hot at full speed. That can burn the exhaust valves.
Check with the distributor cap off. Turn the rotor in the direction it turns with the engine running and it should allow some motion and snap back when released. If not its time for more work deep in the distributor. Oil on spark plug threads could be from oil in the cylinder from worn piston rings or intake valve guide but it should be showing blue smoke in the exhaust from burning oil, or it could come from a leaking rocker cover gasket dripping oil down the side of the head at the plug. Leaky rocker cover gaskets come with overhead valve engines, sometimes even new ones. Gerald J. |
Dave(inMA)
Posted: 25 Oct 2016 at 8:37pm |
It's a distributor. Will add checking the advance to the list....I need to take this tractor to some place where I can put the hammer down - no chance to see what happens under a good load here at my place! I'll also check the rocker cover gasket - I'm not seeing any blue smoke.
Edited by Dave(inMA) - 25 Oct 2016 at 8:39pm |
WC, CA, D14, WD45
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5188 |
Posted: 26 Oct 2016 at 9:34am |
... and if you are using Champion spark plugs, replace them!
Allen Dilg
Posted: 26 Oct 2016 at 10:46am |
Hello Dave Can you change anything by chocking it??
cpg
Posted: 26 Oct 2016 at 2:03pm |
I would also say start with basics. Fresh plugs with correct gap set, and I have had the issue with wires too. Like others said make sure they are the copper solid core and not suppression core as the suppression core just adds resistance for the modern electronics you don't have to worry about on old tractors. They need all the current the ignition system has. I also agree with checking the cap and and rotor for wear or corrosion.
bigredisb
Joined: 16 Aug 2016 Location: Racine WI Points: 185 |
Posted: 26 Oct 2016 at 2:22pm |
Best place to start on any good tune up or diagnosis is a compression test. If the compression test results are unfavorable then move to a leakdown test to determine where the leakage is.
If your tests are good then its worth putting some money in plugs, plug wires and so on. If the test is negative then save your money for the larger repair needed that you would have discovered with a leakdown test. If your compression tests are good and balanced I personally go to a temp gun on each exhaust port to see if you have any radical differences in outlet temp (can be tricky on tractor exhaust manifolds to isolate each cylinder). If you do have certain cylinder higher than others I test for vacuum leaks around the intake to head ports by using carb cleaner while its running. Lets face it, these old tractors have a lot of hours on them and most likely the oil you are seeing is from the rings letting oil past which isn't always a bad thing. When we build older engines that are running todays gas we like to see the valve stem to guide clearance a little more open to prevent valves from sticking due to the higher combustion temps with todays gas. Edited by bigredisb - 26 Oct 2016 at 2:23pm |
1961 Allis-Chalmers D15
1949 Farmall Super A |
Dave(inMA)
Posted: 26 Oct 2016 at 4:29pm |
Thanks for all the advice. I'll dig into this when I get back to Massachusetts.
What plugs are best to use?
WC, CA, D14, WD45
Brian Jasper co. Ia
Posted: 26 Oct 2016 at 4:45pm |
Carbon wires are not your problem unless they are actually faulty. I have a set of BWD carbon wires on my CA. They've been on there nearly 20 years. My Oliver 60 has them too. They've been on it 9 years. Don't waste your money on the elcheapo wires from fleet farm stores. Buy a quality set like Taylor Cable. You can get a universal cut to length set from Summit or Jeg's. Taylor Spiro Pro would be about the last set of wires the tractor will ever need and they aren't all that expensive. Pitch the Champion plugs and go to AC Delco, NGK, or Autolite.
What kind of shape is the distributor in? If the shaft is loose in the bushing, your Dwell and timing will not be consistent. Remember when you check the timing to do it at full speed. That's when the fire line should be centered in the window. Over advanced from setting timing at idle speed will make them run bad. |
CTuckerNWIL
Posted: 26 Oct 2016 at 5:42pm |
They way it sounds to me, I would do a regular tune up, make sure it has fresh gas and add a half can of Sea Foam, put a 53 SC plow behind it and work the pi$$ out of it for a day . You might need 10 or 15 acres for that
Dave(inMA)
Posted: 26 Oct 2016 at 7:10pm |
Thanks, guys. I'm hoping that some TLC maintenance will get her running better - and I'd like nothing better than to hook my SC plow (sadly only 2 bottoms) on her and plow a good sized piece. We need a major plow day around here!
Dave
WC, CA, D14, WD45
WF owner
Posted: 26 Oct 2016 at 7:41pm |
You have received a lot of good suggestions.
Have you checked the inlet or screen of your sediment bowl, to make sure it isn't partially plugged? |
Robacpuller
Joined: 07 Apr 2016 Location: Wisconsin Points: 248 |
Posted: 26 Oct 2016 at 7:59pm |
What about the air cleaner, make sure it's breathing
Robacpuller
Posted: 26 Oct 2016 at 8:01pm |
Put a pertronix electric ignition in, your problems will b solved.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5474 |
I would also add some Seafoam to the crank case. Not sure how recent of a oil change you have, but if you haven't changed it remove enough oil from the crank case to allow you to add Seafoam in it's place. Instructions are on the can for dosage. Seafoam has done some increadable results for me in several engines that I have worked on. It cleans the engine, removes condensation, loosens and cleans piston rings, pistons, valves, valve guides.....and more. i bought a non running 720 a few years back. Once I made repairs to get it running, it puffed blue smoke worse than chain smoker and only got worse after 5 minutes. I removed some of the new oil and added Seafoam. Within 4 minutes of 3/4 throttle running , smoke was barely visable. After 15 minutes it was gone. I drained the oil and it was deep black. Put fresh oil in with more Seafoam and ran it off and on for 2 weeks. Drained and added fresh oil only. It not only stopped the smoking, compression increased in each cylinder and is close to being even. It runs great and uses no oil.
Dave(inMA)
Posted: 26 Oct 2016 at 9:30pm |
Thanks to all of you.......pretty sure I've got strong fuel flow to the carb and had thoroughly cleaned the air cleaner. Replaced the missing tube from the air cleaner to the carb with no change in the way the engine runs. But both worth checking. Will add the Seafoam treatment to the list!
Dave
Edited by Dave(inMA) - 27 Oct 2016 at 2:47pm |
WC, CA, D14, WD45
Dave(inMA)
Posted: 03 Nov 2016 at 5:09pm |
Some updates now that I'm home for a few days:
1. The advance seems to be fine - the rotor turns 5-10 degrees and snaps back nicely. 2. There seems to be play in the dissy shaft. Not a lot, but I can feel play in the shaft when I pull on the top end of the shaft. 3. Good fuel flow to the carb. Would a set of new bushings and a shaft cure #2? Thanks much! I really appreciate the help. Dave
WC, CA, D14, WD45
DiyDave
Posted: 03 Nov 2016 at 6:43pm |
I't take the dist off, and take it to a good electric rebuilder shop. They have the tools, and equip, to do it right, and access to the parts. If the shaft wobbles enough to close the points, its overdue...
Dave(inMA)
Posted: 03 Nov 2016 at 7:22pm |
I'll make that test tomorrow, DiYDave. Nice to have a standard to measure against!
Edited by Dave(inMA) - 03 Nov 2016 at 7:22pm |
WC, CA, D14, WD45
