WD45 engine clutch disc opinions |
bozrae
Topic: WD45 engine clutch disc opinionsPosted: Yesterday at 6:55am |
This might be opening up a can of worms asking for opinions, but it seems there are 2 different clutch disc available for the 45. One being a fabric style and the other a 4-pad. The 4-pad seems like it may hold up to more power though. The engine will have the 4-1/8 overbore sleeves and pistons so it may have a few more horses then when new.
Does anyone have experience with these in a 45? Thanks
D15D, D17G, 170G, 175D, and two 5050FWA
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1332 |
Posted: Yesterday at 8:29am |
You will want the heavy duty style.
![]() This is the style I prefer. Edited by 55allis - Yesterday at 8:30am |
Posted: 19 hours 41 minutes ago at 9:47pm |
How are you going to use the tractor ?? Those button clutches are made for more grabbing power with the same diameter/size and squeeze on the clutch disc. There's no need for that unless you have a pulling tractor that makes 75 or more HP. The button style discs are very hard on the flywheel and pressure plate surfaces over time as they eat away the metal. You do however want a 9-spring pressure plate for any WD-45.
55allis
Posted: 18 hours 47 minutes ago at 10:41pm |
I have one like above on my 45 diesel repower with no problems. Dynoed at 91 hp.
Posted: 18 hours 17 minutes ago at 11:11pm |
Re-powered with what ??
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8971 |
Posted: 17 hours 55 minutes ago at 11:33pm |
Think he's got a D19 engine
bozrae
Posted: 11 hours 55 minutes ago at 5:33am |
Thanks for the comments. The hardest work the tractor will probably see is pulling a 3-bottom snap coupler plow at plow days. Looks like I'll go with the fiber disk and it already did have the 9 spring pressure plate.
55allis
Posted: 3 hours 47 minutes ago at 1:41pm |
Yes a D19 diesel with the turbo. |
Posted: 3 hours 43 minutes ago at 1:45pm |
Head gaskets last longer at 66 factory rated HP than 91 HP.
55allis
Posted: 3 hours 14 minutes ago at 2:14pm |
I have an oem head gasket with hylomar head gasket sealer. No problems yet.
Also replaced the head bolts with ARP studs Edited by 55allis - 3 hours 14 minutes ago at 2:14pm |
