wd45 Dsl engine parts value
coop97 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 Dsl engine parts value
    Posted: 09 Dec 2010 at 6:00pm
I have some WD45 dsl engine parts I want to sell.
I have
WD45D Crank, crank pulley, cam,oil pump, oil pan, and front engine cover.
I also have an adapter plate,clutch and pulley assembly for 262,230 for Gleaner combine if anyone is interested.
Does anyone know the going prices for thes parts?
56 WD45 DSL,55 WD45 DSL,53 WD45,50 G,48 C,37 A,30 E 25-40,28 E 20-35,79 5030
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2010 at 6:38pm
Would depend on condition of Crankshaft, Is pulley 1 or 2 belt? oil pump mount tabs good? Front engine cover, not worth much, oil pan??, Cam does it need grinding??. A good crank, 10/10 turned, checked out for condition w/bearing set can fetch $500 to someone who needs one, that may be the problem, not many lookers I suspect. Pulley if not all grooved up, $50+/-.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 8:12pm
coop..you dont have a 230 buda diesel block out of a 45 do you???
