WD45 drawbar tight or loose?
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: WD45 drawbar tight or loose?
    Posted: 28 Dec 2010 at 9:16am
Just got to wondering... is it supposed to be loose, slide easily front to back in the bail,  or is it supposed to be tightened right down? Dad always left this one kinda loose, and when ya stepped on the drawbar to get on the tractor you could hear it clank in the snap coupler bell.How do you guys run yours? thanks.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 9:51am
My dad always left it loose. I would tighten it up-He would loosen it. With it loose on the D-17,it would let our fold-up hay tedder flop back and forth when it was in transport because it was almost balanced on drawbar. Dad died 3 years ago and now it stays tightened up in a rigid position all the time. I think it works much better this way.
DLS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DLS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 10:01am
Should be left loose. If you tighten it down you are stressing the bail and the brackets on the bottom of the axle. Runnning with it tight is why you see so many bails that have been broke and welded.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 10:15am
Loose! That clanking noise is how I know Im on a 45! The sound is copyrighted too! ALLIS MUSIC !!!!!!!!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 11:34am
I agree with loose.  This way, the pull is coming from the snap coupler unit, and not the bail (when it gets tightened down).  The bail was designed to hold up the drawbar - it is not a pulling point.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 12:29pm
I vote for loose also, it is much easier to install the drawbar if the drawbar is loose on the bail. It also makes it easier to adjust the drawbar height.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 12:57pm
loose is how we have ours
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 1:04pm
If it is not loose on the bail the traction booster will not work properly.
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 2:06pm
lOOSE
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 2:38pm
Some one find an old operators manual!Ours have been tight since ownership.Push bail fwd and pull bar back to get the play out and tighten up.The bail on dad's Wd(bought new in 49) was broke before the snap coulpler was installed around 70.My 56 WD45 has not been broken(bail) and I've had it since 80. Both are working tractors.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 2:47pm
loose if pulling implements . If tractor pulling lock it down tight.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 2:49pm
We always had ours loose and used old bolts to keep it from swinging, but also let it swing when pulling a chisel often. I don't remember it ever being clamped down.  Bails never broken, but they were diesels and I think a lot of broken bails were from the snap of the gas engine.
ALLIS EXPRESS!
This year:
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 2:50pm
I agree with Steve,  we ran it pulled to the rear and biased down, then tightened.  This makes for a quieter tractor, kept slapping of the gear shift lever to a minimum.  The whole drawbar assembly lasts longer when the sloppiness is removed, this makes the next owner pleased by the manor in which you took care of it.  How does one determine if something is going wrong when you hear the SC release lever slapping the gear shift lever when you should be looking further.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 2:55pm
I dont have a wd45 operators manual. I do have one for a d14 . It has to do with the load but wants it to be able to slide side to side and be as low as possible with heavy loaded wagons or such.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 3:23pm
They are all run loose around here!!!! There are alot of WD's,WD45's and D series around here in PA.
wd4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd4ever Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 3:32pm
We always had them loose and mine is loose to this day. I have not seen any undue wear at all. When we bought the WD  the AC dealer set it up loose and stated it should be that way. Lots of water over the dam since then and never broke anything.
I have all the manuals, operating, shop, maint and parts. Don't see anything in any about the subject discussed. Lots about setting up power lift, traction control etc.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 5:50pm
I just don't agree with leaving it loose. all that flopping around means wear on attachment points. When you hook something to the hitch on your truck, you don't want the bumper or hitch flopping around do you? So there you go. Tighten it up and you will be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 6:14pm
Mine is snug cause I robbed the like new drawbar off my 51 WD. It is still loose enough to slid back under load and operate the TB. If I disc with a wheel disc I want the TB to work under load so I can snitch a little if I get in too deep or have trouble pulling up a sandy knob. If it was tight, the TB would not be able to operate.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 6:23pm
Dads has been loose for over 35 years. I always remember the "clank" of it everytime i get on it. My 45 is loose but I have the front end pulled up tight for drawbar height for tractor pulling only. If im using the tractor for any farm work it stays loose. I do not own a tractor with a drawbar that is tight, all of them have play in them. If you go to the dealer and look at a new tractor, I'll guarantee the drawbar will have play in it. It things cant flex or move a little bit they will break.
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:30pm
mine is loose
1955 WD-45 with factory PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 11:39pm
I ran mine loose when pulling a 4-14 drag plow with a hyd lift.Could get some TB lift cheat in tough spots
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 6:05am
Our WDs and D series have always been loose. As I have witnessed on my uncles tractor the bail breaks when a pin falls out and this is because he used a bent nail to hold it in instead of the correct hair pin. That said on the 190 I have tightened it as tight as I can get it or the chisel plow jumps from side to side when in hard ground but that still doesn't quite stop the jumping. That ground was hard this year and I suspect it will be next year too because too much snow doesn't let the ground go through any freeze/thaw cycles.
Wink
I am a Russian Bot
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 8:27am
Hope you can read this, but it looks like both answers are correct, per the operators instruction manual for the WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 8:45am
"When drawbar control is not used  keep drawbar clamps tightened to eliminate wear on drawbar and keep universal joints in alignment."
            I have been vindicated!!
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 9:15am
   That's a pin hitch, not Snap Coupler.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote wd4ever Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 11:54am
We kept the pin hitch loose also on the early 1948 WD, before the snap coupler. I guess it is simply to each his own.Worked a dairy with 200 acres under till with a WD and a JD H model so the WD saw plenty of hours. Never found any extra wear from being loose front to back.  Side to side we kept it centered with a couple of bolts through the holes but it was not tight.  When you work with tilling equipment which is not mounted you need the draw bar to swing side to side to get decent sharp turns. In 1948 we still had a lot of converted horse drawn tilling equipment, not mounted. Remember the WD's never came with three points like we have today. Today I work the WD with snap coupler items.
Dave
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 7:01pm
Here you go. This is out of my WD45 book.
