WD45 Diesel Power Steering Pump Drive Coupler
GlenB(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Diesel Power Steering Pump Drive Coupler
    Posted: 20 Apr 2023 at 3:29pm
I am looking for a good coupler that joins the power steering pump shaft and the generator shaft on a WD45 diesel.  The splines are chewed-up inside mine.  Have not checked AGCO yet.  Any advice is appreciated.  Thanks!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 4:07pm
Make sure the splines on the back of your generator are good too.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 6:50pm
About a year ago somebody on here had a miscellaneous assortment of parts for sale and several of those couplers were in the group. I would try Agco and keep us posted! Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 9:45pm
I just ordered one from SLI a month ago for my D17.....hope your sitting down, $94. As said above check both the generator and pump shafts to make sure they are in good shape. If those splines are really worn they will need to be replaced. Replacing the pump shaft isn’t difficult but the Shaft in the generator should be replaced by someone like Steve in NJ.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2023 at 10:30pm
Did you get a coupler yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenB(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 7:03am
I had the generator rebuilt and the splines there are good.  I will check with my AGCO dealer today for the coupler.  I just wanted to see if anyone else had a good source.  Thanks for your help guys!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 7:16am
In the mid '50's Chevy P/S used the same set up, might try them or salvage(55-57)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 3:09pm
Mike, do you have a coupler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2023 at 5:42pm
Yea I private messaged glen
This page was generated in 0.434 seconds.
