Wd45 diesel generator repair |
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1147 |
Topic: Wd45 diesel generator repairPosted: 14 Nov 2025 at 6:07pm |
Good evening!!
Is there a source for the original 12volt generator parts? I notice the brushes are very well worn and it’s not charging very good. I’d prefer to leave it original with the power steering pump on the back of it if it’s possible. Thanks |
Phil48ACWC
Posted: 15 Nov 2025 at 5:09am |
Most likely it is a Delco Generator and same as from a '50's to early '60's Chevy generator. Take yours apart to confirm, click on below, scroll down, and take your pick:
Edited by Phil48ACWC - 15 Nov 2025 at 1:25pm |
Alvin M
Posted: 15 Nov 2025 at 6:49am |
AGCO Has Them Part # 70231998
Edited by Alvin M - 15 Nov 2025 at 6:50am |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7550 |
Posted: 15 Nov 2025 at 7:49am |
A local starter/alternator repair shop can make it as good as new.
55allis
Posted: 15 Nov 2025 at 11:52pm |
When I’m done using the tractor I will slip it apart and confirm what it needs, only want to pull it apart once.
What involved in resealing the power steering pump on the back of the generator? It seeps enough to make a mess of the generator parts. Got an itch to get the leaks sealed and the charging/wiring working properly. Thanks |
Phil48ACWC
Posted: 16 Nov 2025 at 6:48am |
PS pump probably needs a seal replacement. Get the numbers off the seal and measure the seal when you take it apart and get a new one from Ebay or any seal supplier on line, unless you want to pay nutso pricing from Agco. Also keep in mind, the '57 Chevy came with a generator with the PS pump attached. So that will narrow your search for parts.
Edited by Phil48ACWC - 8 hours 49 minutes ago at 6:17am |
