WD45 & D17 series 1-2 final drive |
grinder220 ![]() Orange Level ![]() Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2370 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Jun 2022 at 8:57pm |
Are they the same or is there a difference between the 2.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21835 |
They would interchange as an assembly, as they are the same ratio. If you look thru AGCO parts, you'll find there are many things that have different part numbers on them. So, they changed things over the years for more strength and durability.
Heaver gears and a lot stronger stub axel. WD will twist axel once in a while, but have never saw a D17 axel twisted. MACK
