wd45 crankshaft |
woody4178
Topic: wd45 crankshaftPosted: 14 Jan 2014 at 12:51pm |
Is the ac wd45 226 crank the same crank as the 226 leroi
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 14 Jan 2014 at 1:00pm |
Someone will chime in but I believe the leroi main thrust bearing is in the middle and the allis is on the end.
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Posted: 14 Jan 2014 at 1:53pm |
The front of the Leroi crank is to narrow for the thrust bearing, you need to have it ground wider by just a few thousandths. Other than that it will fit. You could shim the crank gear out, or machine the thrust bearing narrower to make it work also if you had to but grinding the surface is simple to do in a crank grinder.
I've used the Leroi cranks in Allis blocks several times, it's simple. Just the clearance issue on the thrust bearing. |
woody4178
Posted: 17 Jan 2014 at 1:24pm |
Thank you wi50
