wd45 crankshaft
woody4178 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody4178 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 crankshaft
    Posted: 14 Jan 2014 at 12:51pm
Is the ac wd45 226 crank the same crank as the 226 leroi
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2014 at 1:00pm
Someone will chime in but I believe the leroi main thrust bearing is in the middle and the allis is on the end.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2014 at 1:53pm
The front of the Leroi crank is to narrow for the thrust bearing, you need to have it ground wider by just a few thousandths.  Other than that it will fit.  You could shim the crank gear out, or machine the thrust bearing narrower to make it work also if you had to but grinding the surface is simple to do in a crank grinder.
I've used the Leroi cranks in Allis blocks several times, it's simple. Just the clearance issue on the thrust bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody4178 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2014 at 1:24pm
Thank you wi50
This page was generated in 0.138 seconds.
