wd45 crankshaft
Message Reverse Sort Order
jvin44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin44 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 crankshaft
    Posted: 13 Dec 2015 at 8:04pm
Ok sounds good thank u
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 8:01pm
Yeah, I'm pretty damn sure. Just goes to show how "after-market" parts suppliers don't always have their act together. The model D-17 engine has larger main bearings, not a WD-45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin44 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 7:54pm
Are u sure cause the main bearing parts are listed as wc wd and early wd45 and I been told the later wd45 are different and thats the way parts, are listed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 7:14pm
All main bearing journals for a WC-WD-WD45 crankshaft are the same diameters. Some very early WC's had smaller rod bearing journals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin44 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2015 at 6:56pm
I have a wd45 engine trying to determine if it is small main journal or large serial number is 45-31558-g
