WD45 Crank Question
CTALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Crank Question
    Posted: 20 Dec 2021 at 5:28pm
just pulled the crank (226535) out of a wd45 and found shims on the mains.Thought on the WD's where shimmed.
engine number is 45-85727-G
Going to need another crank.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 6:10pm
Main bearings were always shimmed on WC/WD/WD45 gas engines. Rods are shimmed on WC and WD only. New main bearings usually need new shim stacks. If your shim stacks measure .010" each they could be reused I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2021 at 6:41pm
Thanks for the info
