wd45 crank driven hyd pump |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3892 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Feb 2022 at 10:23pm |
whatshould i order that will replace the pto pump for my f11? any certian brand size model , loader valve is open center . i need to have use of the pto beside the loader this year . and i do not want to keep taking the pump off and on. and i do not want pto stub out of the end of the pto pump, i think my pto pump is a 21 gallon per minute
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 616 |
This is the kit for WD & WD45
i have the pulley for the factory power steering , what are the specs. on that pump
I don’t know for sure probably around 12
gallon at full throttle on WD45. It came from Norther Hydraulics and has a
12/1999 code date. If you have salvage yard close by the pumps off of the
Gleaner A, C, F will work |
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1278 |
I bought the longest pump I could with a 5/8 shaft, and I think I maxed out at 14/gal a minute.
Not gonna fit anything bigger in that space I don't think very easily. |
