WD45 Carburetors
Dan1129 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan1129 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Carburetors
    Posted: 03 Oct 2019 at 4:01pm
Restoring a 1956 Wd45 with the Tsx 464 carb. I purchased a used Tsx422 said to come off Wd45 but it’s smaller of course then the 464. Can I run the 422 carb on Wd45? How much will this effect the tractor? Thanks Dan Southern Iowa
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 4:20pm
The 422 usually comes on the 201 WC/WD engine which is the small bore Carburetor.  The 464 is a large bore Carburetor and is jetted quite differently from the small bore Carb. If you got it to work, I can tell ya right off the bat it would be to lean for the 226. If you have the 464 off the Tractor I offer rebuilding services and I can rebuild the unit for you. I also might have a 464 on the shelf ready to go. I'd have to check....
Steve@B&B
festus51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus51 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 5:27pm
steve are the one that has wiring harnesses?
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2019 at 8:07pm
What's wrong with the 464? Rebuild it or ship it to Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 12:43am
Have a rebuilt TSX561 (which is the 464 replacement) on the shelf. $150.00 exchange or $175.00 outright.
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2019 at 4:55pm
Yes. The same Steve.
bb-customcircuits.com
