WD45 Carb HELP
devron30 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote devron30 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Carb HELP
    Posted: 02 Jan 2022 at 8:02pm
I have a WD45 and it cracked where the fuel line goes into the carburetor. I am looking for a new upper or whole carb. Where can I locate one. Thank you!
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 9:11pm
Marvel or Zenith ? You have any numbers from your carburetor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 9:54pm
The crack is from overtightening the elbow fitting. Depending on how bad it is, remove the fitting and have someone braze the crack shut. Reinstall the elbow with loctite on the threads and let cure overnite. I bet it can be fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote devron30 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 11:54pm
It is a MS TSX-464
