WD45 Carb Adjustment
jyanna View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jyanna Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Carb Adjustment
    Posted: 13 May 2012 at 11:57am
THanks to you all, I have solved my WD45 starting problem.  Repaced the carb, replaced he manifold gaskets, checked compression (all cylinders good).  At this point, once it starts it runs BEAUTIFULLY.  The problem is, it starts hard.  I generally have to crank away for some time to get it to kick over.  Is there some final carb tweaking necessary?   Thanks in advance!
