WD45 Can't engage trans. if started in neutral |
dpehrson ![]() Bronze Level ![]() Joined: 09 Jun 2012 Location: Preston,ID Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Jun 2012 at 9:59pm |
I am a new owner of a WD45. The previous owner accepted and lived with this problem... The problem is that if the engine is started with the transmission in neutral, clutch engaged or not, the transmission cannot be placed in any gear due to grinding of gears due to transmission rotation, dispite clutch engagement. The only way of placing the transmission in any gear is to do it before starting the engine and then depress the clutch upon starting. When starting it in this manner, the transmission can then be shifted into any gear as normal, however, if at any time the clutch is released, with the transmission in neutral, it only grinds and you have to shut the engine off and start it in a gear to proceed.
I have tightened the clutch pedal travel so that there is about 1 inch of travel before forks touch the throwout bearing without resolution.
Is the problem a very stiff or seized pilot bearing that is allowing the transmission to rotate regardless of the disengaged clutch?
I would say there is oil and dirt on clutch disc. Pull motor and clean up or replace. MACK
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
Try engaging the hydraulics with the clutch pushed in. That will create enough drag/load to stop the gears spinning.
mattb ![]() Orange Level ![]() Joined: 11 Jan 2011 Points: 348 |
pull the bottom cover off bellhousing and make sure all three pivot pins are in ur pressureplate. have had two of them do this. Can put them back in without splitting.
Dusty MI, THanks for the post...
However, I am quite a newbee at being a WB45 owner and have received nearly no instruction on operation of this model...Other than simply moving the hydraulic control lever all the way up on the quadrant, is there another way of "engaging" the hydraulics, or is this what you are referring to?
MattB,
Thanks for the mechanical/inspection information. I am an experienced drivetrain mechanic and will do as you have suggested, however, since I have only owned the tractor for one day and am not familiar with this model specifics or have a service manual yet, would you be willing to expound a bit more detail on this process. Pictures and/or illustrations are great if able...
THanks a million!!l
Are you referring to the pins that hold the three pressure plate fingers in place upon which the fingers pivot on when clutch is engaged? If so, I am familiar with that inspection... thanks... |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Could also be a warped clutch plate. Try minimizing the clutch pedal free play to get more stroke at the throwout bearing.
Gerald J. |
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3929 |
I just had a similar problem on my D17. The clutch assembly fits into a recess in the flywheel and there is not much clearance between the outer rim of the clutch disc and the recess in the flywheel. There was so much dirt and crud in there that it continued to drive the clutch disc even tho it was disengaged from the pressure plate. I split the tractor and cleaned it out and installed a new clutch and throwout bearing, even tho the old one looked not bad. (Didn't want to have to split it again!)
WD45 has the same flywheel/ clutch setup. Edited by Alberta Phil - 12 Jun 2012 at 10:42am |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8647 |
same design Phil,but flywheels are much different
Thanks for the recommendations Gerald J, but I have already taken as much slack out of the linkage adjustment as I dare...about an inch of pedal freeplay before throwout engagement. Alberta Phil, When I pull the clutch cover off and check for those finger pins suggested earlier, I will also check for the crud build-up as you have discribed. I am sure trying to avoid spliting this old girl and hope that it is either the pins or debris.... Thanks, Dave |
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
You might reset the three finger height to out-bearing.
I don't yet have a manual. Perhaps someone can scan or outline the specifics and tolerances on "reseting the three finger height to out-bearing" adjustment?
Thanks, Dave
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Since you have only had it 1 day, do you know if it was doing it before you bought it? If it suddenly occured, I'll bet on broken pressure plate fingers. If it started slowly, I'll bet on pilot bearing in the flywheel.
JimD
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
Jim D,
The previous owner stated the condition before I purchased it. I thought it would be just a matter of a freeplay adjustment...I seems to be deeper than anticipated...I will have to pull the clutch plate off and take a deeper look for broken/worn/dirty componants.
I was stumped mostly because of the ability to shift consistantly only when it is started with the trans in gear and clutch depressed. If at anytime I release the clutch with trans in neutral (engine running), and then depress the clutch to put it in gear...no way, all grinding. I must then shut the engine down and start her with trans in gear and clutch depressed... Edited by dpehrson - 12 Jun 2012 at 1:55pm |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Could also be a dry pilot bearing dragging, not letting the shaft stop turning???????????//
The clutch pedal can have as little as 1/4" of free play to give more motion at the throwout bearing. Good at least for a test.
I had an 8N years ago that acted a lot like that, and that was a clutch plate sticking to the flywheel or pressure plate. I put the front against a solid obstacle (sturdy corn crib or power pole), started it in 4th gear and polished that assembly with the engine at full throttle and that cured the problem. I slipped that clutch a lot in that situation. Thing is all the posts are possible, there's not one that the tractor is predisposed to have more than any others, so you can do little without looking in and odds are it will take new parts after splitting the tractor. The pilot bushing, the flywheel covered with rust, the pilot shaft covered with rust, the failing clutch fingers, the broken clutch springs, the warped clutch plate, the sticking clutch plate, the clutch finger pivot pins, or excess free play at the pedal are each possible and there's no certainty that only ONE is the culprit. Gerald J. |
GlenninPA ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
I have a B that the clutch plate sticks on. I don't use it enough to keep it polished, every spring I have to do the polish thing with it using 3rd gear. At some point I'll probably tear it down, but that day is farther down the road than I want to think about right now.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
I agree with you all on the possibilities, just as Gerald J. has listed any one or more potential culprits. It is now up to me to tear into her and find out for sure. After I have remedied the problem(s), I will post it here...
I just purchased the PDF downloads, from Ebay, of the WD/WD45 Tractor Service Manual, WD45 Operating Instructions and WD45 Operating Instructions and Repair Parts Illustrations Manual for the very reasonable price of just under $12...I'm ready now for my initiation into old tractor repair...
![]() If there is anybody that has further recommendations on manuals pertaining to the operation and maintenance of the 1955 WD45 tractor, I would greatly appreciate your suggestions.
Thanks,
Dave
ya i was talking about the clutch release lever pivot pins on the pressure plate.
