WD-45 brake pins
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 brake pins
    Posted: 25 Feb 2010 at 8:00pm
I know its been talked about before. but what is the easiest way to get them out without wrecking them. last time i welded a nut on them and used a slide hammer, but i wrecked the pins. any info appreciated.
Thanks, Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 8:07pm
From what I've heard, a few choice words might help if you soak em in kroil for a couple months ahead of time. Somebody talked about drilling and tapping I think. Other wise a gas axe will remove the inner most part and you drive it in till you can cut it off again.
Edited by CTuckerNWIL - 25 Feb 2010 at 8:10pm
DaveS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2010 at 8:13pm
The method I have used to remove the pin is to grind a little off the end of the pin to remove the case hardened surface, drill and tap either 3/8 NC or 7/16 NC thread. Use a grade 8 bolt and hard washer with a sleeve over the pin as a puller. Sometimes you have to drive it in and pull it out as far as you can and repeat until it loosens enough to pull it out. The pin can still be reused with this process.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 11:26am
personally I drilled and tapped them as stated above.  but if you don't want to fix the pins afterwards, A&I sells them brand new for less than $5.00 Canadian a piece
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2010 at 6:10pm
As CTucker said gas ax works I used 3/4 in cold rolled to make new pins, Mark
This page was generated in 0.180 seconds.
