WD-45 brake pins
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 brake pins
    Posted: 15 Jun 2010 at 9:48pm
what i've found to work the best is a slide hammer. just finished pulling out my second set of pins, last year did the WD now the WD-45. we welded a nut on the pin, then welded a pipe on the nut, then put another nut on the end for the slide hammer. used the fire wrench a little bit to help em come, but i highly recommend doing it this way.
Carl.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 5:45am
Great set of pictures, Carl - there's hope for those of us who have yet to try this! Looks as though rotating the bull gear case 90* is part of the recipe - yes? How heavy is that slide hammer?
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 8:27am
yes, first time i did it, i pulled the pan, took out the bolts and twisted it 90* and ran a smaller bolt with washers and a nut. makes things much easier. the hammer is 5 pounds. we also had someone pulling on the end while another used the hammer. works pretty good
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 8:35am
I'm thinking that the heating and cooling after welding on the end of the pin can't be a bad thing either. Might tend to loosen it a bit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2010 at 1:23pm
Thanks, Carl. I think Brian's point is right on. Definitely worth trying.
WC, CA, D14, WD45
