WD45 Bogs Down When Hot
jyanna View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jyanna Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Bogs Down When Hot
    Posted: 31 Oct 2010 at 11:57am
My WD45 starts and runs fine until it warms up.  Then it bogs down and has no power.  Just redid the carb and new plugs.  There is coolant in the radiator.  Guage shows temp OK.  Water pump?  Any ideas would be appreciated.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 1:55pm
Coil ok ?
Check points gap too.
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 2:19pm
I may be out there on this one but I had an old jeep that lost power. The valves had got out of adjustment and would loose power when it warmed up.
Danny Raddatz
kb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kb Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 5:55pm
Our WD45 was doing that same exact thing this spring.  The coil was breaking down and it was fairly easy to figure out as you couldn't touch it hot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 7:00pm
If tappets have been adjusted too tight, they will do that. Adjust to .015" COLD intake and exhaust........don't go thru that .010" when hot B.S.  ...do them all cold at .015" and KNOW they aren't too tight.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2010 at 7:05pm
I would check the coil first and see if it is hot after the engine begins to bog down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jyanna Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 5:07am
Thanks so much for all your suggestions!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 5:19am
Did you find the problem?
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 7:44am
I had that problem with an RC.  Turned out to be a large build up of rust, scale, sludge, etc. around the rear of the back sleeve, so it wasn't cooling and would seize the piston.  It was the original cast iron piston, so the clearances were pretty tight.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2010 at 8:17am
You can try the condenser first.  That is the cheapest fix but normally it is the coil.
Let us know how it goes.
Good Luck!
Bill Long
This page was generated in 0.057 seconds.
