wd45 boble when i pulled it
bhalstead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Topic: wd45 boble when i pulled it
    Posted: 14 Aug 2011 at 11:31pm
i pulled my wd45 tuesday night i pulled it in the 4500 and 5500 it pulled good in the 4500 but in the 5500 at about 150 foot it strted to boble it will boble whn it is not above 120 degres
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 11:39pm
adjust the carb. sounds like it's overloading it
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 11:49pm
iv tried it will keep doing it i have rebilt it
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 11:52pm
Have you adjusted the load needle?
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 11:54pm
Can also be caused if it is not getting enough gas, AC's did that bobel sound all the time at the tractor pulls till they got under heavy load and they'd even out.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 11:55pm
ya i going to buy a new carb
Post Options Post Options   Thanks (0) Thanks(0)   Quote bhalstead Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2011 at 11:57pm
iv richend it up that doest stop the first time i pulled it it didnt do that
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 12:02am
Could even be in the timing. Have you tried resetting the timing? I'm sure somebody around here will have the answer
German Shepherd dad
#WD234847
#WD88193
