WD45 Block
Stan54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan54 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Block
    Posted: 31 May 2016 at 3:01pm
Have a block for a WD45 with main bearing caps that is stripped down and ready to rebuild. Will include a set of pistons and sleeves that are still in the box. My dad was going to restore the tractor but passed away before he could finish the project. How much should I ask for it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 3:53pm
There are 6 possible places for the block to be cracked in-between the bores. How many cracks does it have ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan54 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 4:27pm
Checked out the block, worked it down with sandpaper and found no visible cracks between the bores or on the top. My dad was a AC and a IHC mechanic all his life. I would have been surprised if he would have intended to rebuild a block that was cracked, but weird things do happen I guess. He had several WD's setting around and had intended to restore another one.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 4:45pm
I've been looking for a WD45 block that has been tore all the way down.
PM sent Stan.
Edited by 79fordblake - 31 May 2016 at 5:37pm
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 5:36pm
I just paid $100 for a block plus Fastenal shipping.  Sleeves and pistons, are they stock or 4 1/8 overbore, new or cleaned up?
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 6:44am
are you selling the WD's as well?
