WD-45 and CA Lift Latch Restoration
BMinor0788 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BMinor0788 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 and CA Lift Latch Restoration
    Posted: 13 Feb 2022 at 5:56pm
Guys:
I am going to do a restore on two sets of my WD-45 lift latches as well as the lift latches for my CA. Would you recommend removing the hinge rivet and separating the tops from the hook portions or just leaving them together? I'm going to sandblast, paint and install new springs, and rivets but just not sure how to go about doing the hinge rivets.
Also, do the CA lift latches use the same small twist rivets like the WD-45 latches or are they straight through rivets? I had a junk latch I messed with and it seems like they are the whole length through the tube.
Brandon
CentralMNCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CentralMNCA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2022 at 9:22am
Just completed a set of snap latches for a CA Allis Chalmers  Please send me a private message  and we can text,  I cannot figure out how to send pictures in this forum
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2022 at 12:33pm
I did mine a while back. Just forced off the washers. Then put new springs on and new washers and repeened. Worked out well.
This page was generated in 0.101 seconds.
