WD45 3 pt Hydraulic Lift Problems
Boyd Little View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boyd Little Quote  Post ReplyReply Direct Link To This Post Topic: WD45 3 pt Hydraulic Lift Problems
    Posted: 24 Oct 2011 at 7:06am
The 3 point hydraulic lift on my WD45 lift and lower, but lack any intermediate positional control.  In other words, they tend to go nearly all the way up and all the way down with no "middle ground", so to speak.
Can anyone advise on what needs to be done & how involved (expensive) is it?
Thanks, Boyd
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 7:40am
you need to set your Hydraulic pump traction booster controls to the "Hold" position then it will work better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 7:48am
What Matt said. The hydraulic system has basically 2 different settings. The old Ford tractors had a lever to switch from draft control to hold position but on the WD-CA you have to turn some screws and adjust things according to the manual.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2011 at 7:52am
The 1/4" rod between pump and hold posion valve may need adjusted.  MACK
