WD WIRING
davegoodell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davegoodell Quote  Post ReplyReply Direct Link To This Post Topic: WD WIRING
    Posted: 07 Jul 2019 at 2:05pm
i NEED HELP WIRING A WD.  iT WORKED PREVIOUSLY BUT HAS A SHORT SOMEWHERE.
i HAVE A 3 POLE LITE SWITCH AND A 2 POLE CUT OUT REGULATOR IN THE LITTLE DASH BOARD.  hELP?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2019 at 4:57pm
What symptoms are you having?Has a short somewhere? Did it blow the fuse? Wiring in a WD is very simple. Wiring issues were generally at the lights. They tee just under the gas tank where the light holding rods attach. I had to replace the wiring through each tube. Buy a new harness if the insulation is falling off. Cloth goes bad over time and causes shorts or grounds out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote davegoodell Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2019 at 6:00pm
The wires heat up and the lites don't work and the ammetyer gauge doesn't work.  The gauge is new also.
