WD WIRING |
davegoodell
Topic: WD WIRINGPosted: 07 Jul 2019 at 6:00pm |
The wires heat up and the lites don't work and the ammetyer gauge doesn't work. The gauge is new also.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5477 |
Posted: 07 Jul 2019 at 4:57pm |
What symptoms are you having?Has a short somewhere? Did it blow the fuse? Wiring in a WD is very simple. Wiring issues were generally at the lights. They tee just under the gas tank where the light holding rods attach. I had to replace the wiring through each tube. Buy a new harness if the insulation is falling off. Cloth goes bad over time and causes shorts or grounds out.
davegoodell
Posted: 07 Jul 2019 at 2:05pm |
i NEED HELP WIRING A WD. iT WORKED PREVIOUSLY BUT HAS A SHORT SOMEWHERE. i HAVE A 3 POLE LITE SWITCH AND A 2 POLE CUT OUT REGULATOR IN THE LITTLE DASH BOARD. hELP?
