WD &WD45 wide fronts
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: WD &WD45 wide fronts
    Posted: 23 Nov 2009 at 8:18am
On a 3 bolt front and a 4 bolt front, is the only difference, the front plate? And of course the pedistal? Dave.
John H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John H Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 9:47am
Dave, that is my understanding. The 3 bolts were subject to cracking around the mounting holes when using a loader, and that is why they came out with the 4 bolt version. At least that is what I've been told.  Take care!      John
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 10:15am
the 4 bolt bolster is not as deep into the frame rails. It was introduced the same time as the wd45 diesel to allow room for the motor.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 12:54pm
Dave call me and I'll give you the low down on them. They are the same but not the same.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 4:09pm
Don could you share it hear as I am interested to know too. I may have a chance to buy a WD or 45 with a wide front and I may have choice. What are the pro's and con's of each?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 7:38pm
For Morton and Dave I will put it on here, I just know someone will say I'm wrong, But here go's. There are four wide front ends made for the WD,WD-45 and WD-45-D.
With that said, Here's the short low down on them, The bolster on the first  WD's  up to Ser# 35xxx is one then up to Ser# 136xxx is two, Then at Ser# 186xxx is three (this is WD-45 only) Then the WD-45-D went in to production wide front end on them was made a little diff, for the engine to fit. Now with all that said This is just on the wide fronts. And thats more than I like to type. lol
