wd wd45 steering shaft
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: wd wd45 steering shaft
    Posted: 11 Jul 2014 at 8:58pm
what is the best way to repair the steering shaft bushing on the bracket  by the clutch housing thanks we also  had a great 4th of july show at are place agian this year
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2014 at 10:10am
I would bore it out & put a brass bushing in it.
Ray W.
SC Dan K. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SC Dan K. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2014 at 4:53pm
The brass bushing in the throttle ?
The bronze bushing  in the throttle quadrant wll work to repair this.  If  it is really worn you  might not have to drill it out. I flipped my stearing shaft end over end to get an unworn surface.  You will only have to drill one hole for the U-joint.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2014 at 5:01pm
Dan...He's talking about the steering shaft bushing in the piece on top of the frame rail, I think. Rick
This page was generated in 0.126 seconds.
