WD, WD45 fender identification, question
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: WD, WD45 fender identification, question
    Posted: 02 Dec 2016 at 8:36pm
I'm in the process of restoring a 53 WD (I've known it as "Finlyn" since I can remember) that I learned to drive on 40 years ago. Bought it back into the family about 6 years ago and have been "slowly" reworking the old gal. It was pretty much junk when I got it home. So far I've got the back half rebuilt. The first pic is what we started with. Second pic is how it looks now.
 About 3 months ago I bought a basket case WD 45 that the owner started to restore but gave up on. He had the motor and head rebuilt by a local machinist but couldn't continue on. The tractor has all the parts I needed to finish my WD, I'll be putting the 45 engine in my WD. The tin is nearly perfect on the parts 45. I was lucky enough to get the rust out where the wire runs up for the tail light in the fender. I've never seen a better set of original WD fenders anywhere....if they are original.
First question is in the pictures there appears to be a factory hole in the fenders and fender supports for a fowrard facing headlight and wire to go down the strut on each of the fenders, did the later WD's have field lights on the fenders? Are these aftermarket fenders? The previous owner said they are original.
Next, the parts tractor came with a set of taller fender brackest as seen in the pic. Were they available for a special task or purpose? Should I use them or stay with the standerd brackets?
Thanks for any opinions and information.
Leon B MO
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 8:48pm
you need to send a nice small bale wire through there to pull your lite wire through' will work fine.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2016 at 9:21pm
The taller brackets are for a WD45. They had larger tires than a WD. If you put 14.9 x28 I place of the WD 13.6x28 the tires tear the fenders up when all the way in. We had to change them out on my dads WD when we put new tires on .the allis dealer swapped WD 45 brackets for our WD brackets.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 12:36pm
Leon, what are the measurements on the fender brackets?
If I remember correctly, in the AGCO books they weren't called fenders but some kind of guard......???
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 1:13pm
Personally, I would leave that 45 engine with the 45 rearend, it is much stronger and quieter than the WD rearends... and rebuild the WD engine and finish it off, then go through your WD45 and have two nice tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 6:32pm
You young fart....Wink LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 8:46pm
The parts tractor I bought was a 1950 WD with a 45 motor, my WD is a 53 with the 45 trans rear end but the original 201. So both are kinday misfits. I still wonder about the place in the fender for a forward facing light and place to route wire through fender.
Ted, I just turned 50, so if thats still a young fart in your book, I commend you.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 8:48pm
I don't think there were any holes in the front of the fenders on the WD or 45's. Your current work looks great. Family tractors have a special place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 9:18pm
Dad's WD has more curl on rear of fender than my 45.Must keep wheels on second setting so 14.9's don't wreck fenders.
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 9:32pm
Would anyone be willing to take a measurement of the two different brackets? My WD45 has the 14.9 tires and they will hit the fenders when they are clear in. I am wondering if at some point the brackets were swapped for the shorter WD ones...
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2016 at 11:02pm
the 201 is the right motor for the 53 wd' 226 came in the wd45 same trans an rear end
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 2:21am
My 49 WD came from the factory with a red lensed "Bullet" light, which was the only factory supplied light at that time. I think later versions may have had a white light with a switchable red bulb for night operation. At least I have seen them mounted under the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 6:03am
Jarrod, I'll get a measurement tonight, if I can remember!
Leon B
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 6:45am
There were 3 different size of brackets. I can not remember witch model had the two choices or if both had a choice of two. I have all thee myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 7:41am
Have you got any pictures Lester?  How about some measurements of all three?  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 2:55pm
The three different brackets are from the top center hole to the bottom center hole are from 9.5,  on early one to 10.5 on later one, and the one on my 45D is 12.5 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 7:33pm
Here is pic of the 2 that I have. The tape is hooked on the bottom of the plate at the top of the curve.
Leon B
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 7:51pm
  the wd45 had the tallest brCKET FOR THE LARGER TIRES --FENDER WAS RTHE SAME ALL THE WAY THRU THEMTRACTORS ALL THAT CHANGED WAS THE BRACKETS --USED TO HAVE ALL 3 INSTOCK  WG WAS THE SHORT ONE--THE 45 WAS THE TALLEST SO THE TIRE WOULD NOT HIT THEM  MY 2 CENTS   LESTER IS RIGHT ALSO
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 7:52pm
Thanks to both of you!  Now I gotta measure mine and see what I've got.  I know that my 14.9 x 28's will hit if I pull them all the way in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2016 at 9:39pm
Thanks! Just as Ted said, I will have to go measure mine now!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2016 at 7:47am
Per Parts Catalog: Wheel Guard support
WD to Ser. 146607   P/N 220853 (start of 45 )
WD-45 to Ser. 183207   P/N 226712
WD-45 after 183207   P/N 227012 ( start of 45 Diesel
Gary
WD with curved Shifter and 45 Trans started about Ser. 127007
Edited by Gary - 06 Dec 2016 at 7:50am
This page was generated in 0.123 seconds.
