WD - WD45 air cleaner question |
Post Reply |
Goose
Orange Level Joined: 07 Oct 2009 Location: Melrose, Wis Points: 2471 |
Posted: 11 May 2010 at 1:50pm |
I have a 1953 AC WD that I bought with a WD45 carburetor. I assume it also has a WD45 air cleaner because I think the WD air cleaner is smaller.
Well, the problem I have is that the air cleaner is resting against the exhaust manifold and previously burned a hole in the air cleaner shell.
What do you recommend to make it fit better?
I was thinking of slotting the bolt holes so the air cleaner can move further away, but I thought I'd ask you experts first. I'm sure someone has put a WD45 carb and air cleaner on a WD before and I'd like to find out what you did.
Kip-Utah
Orange Level Joined: 14 Sep 2009 Location: Southern Utah Points: 874 |
An original WD45 manifold or most of the current universal replacement (WC,WD,WD45,early D17) manifolds work better than an original WC/WD manifold with the 45 air cleaner. You can carefully grind your manifold for clearance, it does not take very much, I've done that before. Kip
j.w.freck
Orange Level Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
dont grind the manifold,you will create a hot spot.i have 6 wd-45 and had to relieve the holes on the cleaner mount bracket.dont take much
Post Reply | |
