WD Water pump
TerryMtAuburnIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Topic: WD Water pump
    Posted: 04 Sep 2010 at 4:35pm
What is the easiest way to remove the water pump?
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 4:38pm
Depends on how you define easy. You can fight and work the three bolts out of the pump or remove the hood, grille, and radiator and have easy access to it, either way takes me about the same amount of time
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMtAuburnIA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 4:43pm
OK, thanks alot, I thought there might be an easier way I was missing.
Appreciate your help as always!
This page was generated in 0.395 seconds.
