WD was working fine and now the engine is stuck
jminpa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Topic: WD was working fine and now the engine is stuck
    Posted: 04 May 2010 at 7:20pm
I just got my WD running a couple of weeks ago and only used it about 4 times for 20 minutes max.  I went to use it today and the engine wouldn't turn by battery power so I tried turning it with the hand crank and it wouldn't budge, took the spark plugs out to relieve compression and it wouldn't turn after that either.  Its got plenty of oil and the anti-freeze is full too.
So my questions are what would have caused it to freeze up all of a sudden and how can it be fixed?
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 7:26pm
check your starter it my be the problem.   youmay have  a bad bendex
160 CA 920diesel 5020 HD-3
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2010 at 7:46pm
i second the starter if the engine rolled backyards the snout on the starter is broke and has the flywheel wedged
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 10:19am
Well I took the starter out a bit and the engine turned by hand, so what needs to be fix the starter or flywheel? The starter spins the engine when partly out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 10:28am
Take the starter completely out and look at the end of it to see if the snout is still good.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2010 at 10:42am
Sometimes wear to either the ring gear or the bendix gear causes the starter to jam - I have one tractor on which that happens occasionally. Remember, these girls are 60 years old!
WC, CA, D14, WD45
