Wd vs wd45 rear and transmission
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Wd vs wd45 rear and transmission
    Posted: 27 Aug 2018 at 9:42pm
Wondering which is a stronger combination. I have heard the straight cut wd gears are stronger than the 45 gears and will not jump out of gear. My grandpa was told that 45 rear end and transmission is stronger. This would be for a wd pulling tractor.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 7:16am
Late WD/WD45 helical gear transmissions are STRONGER than the old straight cut gear transmissions.  The early D-17's essentially had a WD-45 transmission in them.  Low gear is a little slower in the helical gear tranny.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2018 at 7:23am
Dr. is right. Late WD/45 are a lot stronger.      MACK
This page was generated in 0.115 seconds.
