WD Tune up
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: WD Tune up
    Posted: 03 May 2023 at 8:45pm
I see on the forum here there is often a lot of references to poor quality imported points, condenser and rotor tune up kits.  I need to give one to my WD.  So, where is a better place to go to find these items?  Thanks in advance for any assistance!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 5:27am
I'll give you my free advice (which is worth what you paid for it).
Since I was a kid, a "tune up" always included points, spark plugs and condensor.
Points do wear out with time, but a lot of points are routinely replaced because we are doing a tune up. With all the imported parts on the market now, I would carefully inspect the points and maybe take a folded dollar bill to clean the contacts, unless you see a reason they need to be replaced.
If there is no apparent problem with the condensor, I, personally, would leave it alone. If there is a reason to replace it, good luck. I went through 3 consensors on one tractor in one summer. Maybe I was just unlucky, but the quality of the new condensors just doesn't seem to be very good.
Spark plugs are like car brands; everyone has their personal preference. I seem to have the best luck with NGK, but others will say they find other brands better, except Champion. I don't know very many that will recommend Champion plugs for an AC tractor.
I think spark plug wires are probably the most overlooked thing on a tractor. I remember when I was a kid, a guy slid off the road near Dad's during dark hours. He walked to the house and Dad took the WD45 to pull him out. The tractor almost never ran during dark hours. When he started the tractor, there were sparks everywhere from the deteriorated plug wires. After installing a new set of wires, the tractor ran much better.
You didn't say if your WD was magneto or distributer. If it is distributer, I would think seriously about changing it to electronic ignition. With the poor quality replacement points and condensors on the market today, it's a good option. I have one tractor I changed over (Dad's WD45) and I have never regretted it.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2023 at 5:51am
Wf is right on the mark. Switch it over and kiss points good by. Steve at b&b has a kit so even a dentist can do it
Dennyswd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennyswd45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 8:53am
I have a Tooth Ache
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennyswd45 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2023 at 8:56am
I also have carbatrater problems.since I cleaned it it wont run and gas pours out of carb
