WD transmission oil?
roadrunner(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roadrunner(IN) Quote  Post ReplyReply Direct Link To This Post Topic: WD transmission oil?
    Posted: 07 Mar 2010 at 9:21am
Do any of you use hytrans in your transmission instead of 80w. It seems like it is suitable for about everything anymore. Thanks, Terry
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 9:28am
RR - Yes you can use hytran in the trans, hydraulic and diff.  I would still stay with the 80EP in the finals. - AL
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 9:53am
Yes hytrans oil is ok for the trans and rear end, But the old seals might leak a little.
I just use 80EP in mine.
Tom IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2010 at 11:12am
AC service manager told me they put hytran in everything even old stuff. The hytran won't leak anymore than the gear oil because it doesn't foam or build pressure. I it is also supposed to be better for the seals.
This page was generated in 0.077 seconds.
