WD transmission gear shift |
Lew ![]() Bronze Level ![]() ![]() Joined: 09 Jun 2017 Location: Buford, GA Points: 59 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Jul 2017 at 10:05am |
Did AC change the transmission gear shift from straight to curved on the WD? I just pulled my WD home and found that it is a 1951 not a 1948 as I was first told. I was given an axle casting number that I checked on instead of the correct serial number. If the AC Company changed the gear shift what year was that change made?
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5029 |
The (very) late WD's and all WD45's had the curved shifter. I believe the change from straight to curved took place in the 1953 model year.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21957 |
Curved gearshift change happened at s/n 127,007 and up. The transmission was of a constant mesh helical gear design instead if sliding spur gears in the straight gear shift models. The older WD transmission was essentially a WC transmission moved rearward.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
The change took place in 1952 and at serial number as doc quoted
Wink I am a Russian Bot |
According to the serial number reference (from this site), the last WD serial number built in 1952 was 126981. If the change was at serial # 127,007, it had to be in 1953.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
There was a break in serial numbers in 1952:
First batch: 105182-126931 Second Batch: 127007-131242 The change in transmission style coincides with the second batch of serial numbers. The "Tall" head was introduced in 1951 with "Engine" Serial #289001. I have my Dad's '51 WD with "Engine" serial #309267 and it has the tall head. |
