WD TRansmission Fluid
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: WD TRansmission Fluid
    Posted: 15 Oct 2016 at 11:26pm
I think the owners manual said to use SAE 140 for A-C WD. Obviously, we wouldn't use that today, so what does everyone use? I have some notes from many years back to use Pennzoil Hydra Trans 90. Is that still accurate? Thanks in advance...
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 7:15am
Use hydraulic wet brake oil or universal hydraulic.   MACK
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 7:17am
I use the universal 303 hyd oil from the local farm store.  Price just went down from $30 to $20 for a 5 gallon bucket.
AaronSEIA
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 7:10am
If I put hydraulic oil in it, I would make sure to use a high quality fluid like John Deere hytrans or other color equivalent. Maybe not needed but I'd feel better. I have 80-90 gear oil in the rear 2 compartments on my 45. Either is fine.
WDDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDDave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 5:52pm
I have 80-90 gear oil In back two compartments in my WD
WD ,wide front, with loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 10:07pm
Any thoughts on this product?
Shell Spirax S4 TXM - Case of 3 (1 Gallon)
Featuring excellent anti-oxidation, anti-wear and anticorrosion properties, Shell Spirax S4 TXM is a premium, universal tractor transmission oil (UTTO) designed for transmissions, oil immersed brakes, hydraulic systems and other ancillary systems. Using the latest friction-modifying additive technology, Spirax S4 TXM promotes more reliable equipment, better performance and less maintenance. Suitable for a wide range of equipment manufacturers, the transmission fluid has a low temperature fluidity and withstands maximum operating temperatures.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2016 at 7:26am
Anything short of Cool-Aid is going to be better than what they had back in the day. My suggestion is go with thicker if you have a little seepage/leaks and go with thinner if you don't have any leaks but no matter what you chose you will be fine IMO. I believe I used an EP80-90 in my rear two compartments on the WD45.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
