WD Transmission (early) |
brownsmule
Joined: 23 Sep 2010 Location: Mooresville NC Points: 1 |
Topic: WD Transmission (early)Posted: 23 Sep 2010 at 3:57pm |
Hello; I need the part number of the needle bearing that goes inside the input shaft and over the end of the pinion shaft on the early style WD transmission. If anyone has a part's book, I would appreciate the look up. In addition; I have a replacement pinion shaft for same and how difficult will it be to change it out; any special tools; and time estimate. I need to get it repaired and out from under the shade tree. Thanks in advance
brownsmule |
