WD Tranny gear swap
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: WD Tranny gear swap
    Posted: 02 Feb 2010 at 3:59pm
I would like to replace 2nd gear for a gear thats a tooth smaller than first. how many teeth did first and second gears have on a WD. what specs do i need for getting some made. after getting the right gears made, whats involved in switching them out?
Thanks, Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:06pm
What are you wanting this swap to do for you? To change any gear, you'll have to change the one it drives also. If you take both gears out and bring them to a reputable gear cutting outfit, they would be able to fix you up if your pockets are deep enough. $$$    If you want a slower gear it might be cheaper to by a set of RC differential gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:21pm
i want to swap because in 5500lbs i lose power, were in 4500lbs first gear is perfect, so if i go a tooth smaller i wont power out as quickly
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:37pm
You don't need different gears, you just need more power:)
Aaron SEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 4:51pm
haha, yeah i know, but new gears will be cheaper..i'd rather have more power.lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 4:23pm
Arouond here a WC or WD needs stroked to even think about competeing in 5000lbs class. Like maybe 400cu in's. So the cheapest route would be to find a set of RC gears to put in.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 6:14pm
Carl, with a little work you should easily get down to 3500, and pull up to 4500 , stock, but 4500 you need to have a good running stock engine. If you want to pull heavier in stock class's you need a D17 for 4500 and up. What are your class rules?, what Div. ? I pulled a stock WD45 for a few years and 5,000 was its practical limit at 3.5 mph and 18" drawbar with 14.9 x28 un cut tires. Occasionally I pulled in other places against Div. 2 tractors with topcuts, and won some . But for 5500 div 2 or 3  you need more power and way more tire.
Edited by Gary in da UP - 03 Feb 2010 at 6:27pm
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:05pm
Hey Carl, if you put a ring & pinion in out of a wd-45 gas that should be about right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:09pm
no one has 3500 around here. i already have the gleaner E with flat top 1/8 over pistons, a pulling carb and plenty of RPM. just need the power to last long in 5500, thats why i want dif gears
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:16pm
I sent you a privet message with what you can do and what I have for sale or know of whats for sale.
This page was generated in 0.136 seconds.
