wd throttle arm |
Sitesstables
Topic: wd throttle armPosted: 29 Jun 2010 at 7:24am |
Ok I can move the throttle lever just fine, issue is if I push it down it jumps back up it will not stay in postion I put it in.. like a spring is super tight.. any ideas what I need to look at?
Lonn
Posted: 29 Jun 2010 at 7:50am |
The spring under the gas tank maybe. I don't remember it's been so long. Also the friction block on the lever and the spring opposite to it on the other side of the quadrant.
Wink I am a Russian Bot |
Mike(SEIN)
Joined: 12 Sep 2009 Location: RUSH County IN. Points: 143 |
Posted: 29 Jun 2010 at 5:45pm |
The springs on the backside of the quadrant get weak from rust. I had this same problem with my WD New springs and new friction blocks helped a lot.
BearcatnorthMN
Joined: 23 Sep 2009 Location: Baudette, MN Points: 123 |
Posted: 29 Jun 2010 at 9:05pm |
I haven't been able to find the springs to replace mine behind my quadrant. I use a piece of a rubber tire about 1/4 inch thick and about 1 inch wide and a couple of inches long and just wedge it between the lever and the quadrant. I have to hang onto it so I don't lose it when moving it but it keeps the lever tight and it doesn't drift. Crude but effective.
