WD Synchro Trans problems
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Topic: WD Synchro Trans problems
    Posted: 18 Apr 2017 at 3:39pm
Please help. Nathan and Charlie Tucker told me how to get tower off (2nd and tilt right). Got tower pivot pins back out of transmission, now for a couple weeks, trying to get tower back in correctly. LittleMarv even drove an hour to my house to help, but even he was unable to solve problem. Can only shift to neutral and reverse. Pulled tower again and took a couple pix,but can't seem to get them to load.
Looks like we have shifter in 2nd in tower before putting together.
Complete flummoxed. Went into all gears prior to taking shifter out to add some size so didn't slide thru and get stuck in 2 gears. Now ball slides thru neutral gate, and into each side ok.
Thanks.
Edited by macvette - 18 Apr 2017 at 3:58pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2017 at 10:46pm
Try natural. 190, yes take it off and on in 2 nd, but WD45, use natural.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 8:38pm
Thanks, Mack.  Put it in neutral, and finally got tower back on.  Now will have to weld and grind some more on shifter ball to make it shift correctly, and not slip and lock into 2 gears.
