WD switch wiring
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD switch wiring
    Posted: 15 Feb 2021 at 5:41pm
My 53 WD with a distributor
My key switch has two terminals
Anyone know what wire from harness, light switch goes to what terminal?
It is all original 6 volt and original key switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 6:17pm
One terminal on switch is longer than the other
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 7:35pm
Wire from ammeter to switch , switch to coil.              MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 8:13pm
Which one goes on the longest terminal?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2021 at 10:25pm
Don't matter.            MACK
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2021 at 8:58am
It doesn't matter in this case. In some cases, the "hot" side of the ignition switch is a good place to pick up power for accessories....hence, the longer terminal on that side of the switch.
This page was generated in 0.095 seconds.
