WD switch wiring |
Matt Tallant
Topic: WD switch wiringPosted: 15 Feb 2021 at 5:41pm |
My 53 WD with a distributor
My key switch has two terminals Anyone know what wire from harness, light switch goes to what terminal? It is all original 6 volt and original key switch |
Matt Tallant
Posted: 15 Feb 2021 at 6:17pm |
One terminal on switch is longer than the other
MACK
Posted: 15 Feb 2021 at 7:35pm |
Wire from ammeter to switch , switch to coil. MACK
Matt Tallant
Posted: 15 Feb 2021 at 8:13pm |
Which one goes on the longest terminal?
MACK
Posted: 15 Feb 2021 at 10:25pm |
Don't matter. MACK
Brian G. NY
Posted: 17 Feb 2021 at 8:58am |
It doesn't matter in this case. In some cases, the "hot" side of the ignition switch is a good place to pick up power for accessories....hence, the longer terminal on that side of the switch.
