WD stuck in 3rd or 4th
jmrehn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Topic: WD stuck in 3rd or 4th
    Posted: 13 Aug 2025 at 12:09pm
I have the shift lever out, looking in I can easily see things are misaligned,Can not get any movement pushing things around in there. Tried it with a real wheel jacked up and rocking the wheel while trying to realign the forks, no luck. So, I am going in to remove the shift tower. A video I watched on this shows removal of the steering post,levers and all attached to it.
My Question is this necessary? can I just remove the bolts holding the steering post, and shift to the side to clear? Probably support it all from above?
53WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 12:31pm
A long flat blade tip screwdriver is what you need to pop things back into neutral. You can only move ONE shift pocket/lug at a time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 12:40pm
I can get no movement at all trying that way. Going out now to give it another try.
Edited by jmrehn - 13 Aug 2025 at 12:42pm
53WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 1:01pm
Smack your screwdriver handle forwards or backwards with the tip engaged in ONE slot inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmrehn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2025 at 2:10pm
Got it,a little more force was necessary, thank you Dr.Allis
53WD
