WD Steering stuck
ACkojack View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACkojack Quote  Post ReplyReply Direct Link To This Post Topic: WD Steering stuck
    Posted: 04 Jun 2023 at 7:28am
I have a WD that sits a lot and has always been difficult turning steering wheel
Now can’t turn at all
Is it gunk in the gear case ?
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 12:36pm
Remove the plate directly above the pedestal and inspect. It's probably dry or loaded with water if stored outside. Clean inside with rags and brake cleaner. Add about 1.5 quarts of 75W-140 gear oil. Available at Walmart. Make a new gasket and reinstall top plate.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 4:43pm
Could be something as simple as a roll pin sticking out in the steering mechanism.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 6:30pm
or one of the knuckles is rusted tight
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 8:48pm
They sure steer better when you put lube in front.                  MACK
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 9:24pm
Mine was the same way. U joint along the frame was seized.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 10:05pm
My dad bought one of the last WD's, it had only been used as a demastrighter. It was the hardest steering tractors I have driven.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2023 at 11:25pm
I agree with Mack
My wd will start to steer hard when it needs a greasing in the wide front knees…
