WD Steering shaft
Matt Tallant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Tallant Quote  Post ReplyReply Direct Link To This Post Topic: WD Steering shaft
    Posted: 21 Sep 2018 at 7:15pm
Is anyone reproducing them?From Wheel to u joint Thanks,Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2018 at 7:18pm
I make my own. Just a piece of cold rolled steel (not hot rolled) cut to length and drill two 3/8" holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2018 at 7:53pm
7/8 diameter if I remember right. I try to salvage mine, mainly because I am cheap. But getting the steering wheel off can take its toll.
Not sure what the demand might be if you were to reproduce them? Couple a year maybe??? Just a guess?
Edited by Sugarmaker - 21 Sep 2018 at 7:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2018 at 7:56pm
Very low demand and the shipping cost for something that size ??????????
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 5:56am
Easy to have a local shop make.  I had to have one made for my WC.
AaronSEIA
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 7:27am
Good morning.   I turned mine around and drilled two new holes. I also added grease nipples and bronze bushings where required.   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2018 at 7:45am
There's nothing that takes away from a nice fresh paint job than a worn and rust pitted steering shaft that is now bright and shiny.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2018 at 8:55am
While you have the shaft out, I'd suggest replacing the tension springs behind the throttle quadrant for the levers. Also be sure to replace the shaft bushing in the quadrant and drill out the lower support by the engine for a bushing or you will still have slop with a new shaft. The old shaft makes a good pry bar or cut it into sections and you have a nice big punch set.
