wd steering box
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Topic: wd steering box
    Posted: 18 Dec 2011 at 6:23pm
my 49 wd steering box is leaking on bottom and where steering shaft enters.  is there any fix for this  what type fluid or grease goes in the steering box??? also how do i get inside.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 6:45pm
I think there is a seal at the bottom.  I can't remember what the book calls for for lube, but cornhead grease works pretty well if the bottom seal is leaking.  Thinner than regular grease, but a lot thicker than any of the heavy gearcase oils.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 7:16pm
Yep, there is a seal on the steering shaft. I put all new seals in my CA when I had it apart in 1998 and I'm going to be using cornhead grease in it when I get it going again. It just won't leak out like the gear lube does.
G226WD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G226WD Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 8:08pm
book calls for NF sae 140..... WF and single front wheel is sae 250
i used 80w90 or 85w140 i cant remember.....
steering shaft just unbolts and pulls out.
cant say about the bottom part
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2011 at 8:34pm
There is also a seal in the bottom of the box below the sector gear and a seal in the bottom on top of  the  spindle block. The problem with these 2seals is when the pedestal gets worn and things slop around a bit. Seals don't like that at all and let gear lube out. I put my WC pedestal in the horizontal boring mill at work, picked up what I thought looked like the original centerline and bored it back round and about .250 oversize. Then I made a sleeve to fit the vertical shaft and presed it into the O/S bore. It really tightened up the slop in the steering.
 You can take the plate off the top of the pedestal in front of the radiator to see inside.
This page was generated in 0.101 seconds.
