WD Starter |
EPALLIS ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1161 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Oct 2016 at 3:59pm |
I hadn't had the WD started in over a year. So, charged the battery, put in some fresh gas a little antifreeze and it started right off. Success! However, I noticed that it turns over "slow". Even with a fresh battery off the charger. Is this a sign the starter needs to be replaced? Or at least sent in and redone? Just doesn't seem quite right that it turns over so slow even for a 6 volt. Thanks in advance.
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
What kind of shape are your battery cables in? I hope you didn't go to an auto store and buy a cheap set of 12 volt cables sometime in the past. It won't hurt if you would remove the cables and clean under all the connections with a wire brush.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
6 volt systems need the battery posts and connectors cleaned twice a year because of corrosion from battery fumes. Timing stuck advanced will slow the world's best starter.
Gerald J. |
Great suggestions. I'll do that before the next start and see if there is any improvement. Thanks!
Well Doug S: I checked my records and it seems I went to Farm and Fleet 6 or 7 years ago and did buy a cheap set of 12 volt cables. So based on your comment I went and purchased a new set from DJS. Installed them today and what a difference!! This problem is all solved now. Thanks so much for your assistance!!
The fatter the cables, the better. I don't know how available nice fat cables are on the retail market. Others feel free to chime in. If not readily available at retail they may be available at an OTR truck repair shop. Fabricating cables from welding cable works too. I'm glad you got it going. 6 volt systems are a little more picky.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12012 |
I make any size cable. Fat or not so fat... LOL!
