wd starter doesn't engage |
irlbeck A-C'S
Joined: 28 Sep 2009 Location: Crestview FL. Points: 689 |
Topic: wd starter doesn't engagePosted: 17 Nov 2010 at 8:47pm |
Just happened to me Sunday on my WD.Took the starter apart and the bendix was broken in two places. Pretty easy fix.
jimwithag
Joined: 21 Sep 2009 Location: Winchester, VA Points: 35 |
Posted: 17 Nov 2010 at 4:10pm |
Thanks for the replies
Jim Cridge
Chris (swIA)
Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
Posted: 16 Nov 2010 at 7:57pm |
Yep. Spring or bolt holding it is broken. Have done both.
fixer1958
Posted: 16 Nov 2010 at 7:54pm |
I agree that the spring is broken on the starter drive if it spins and doesn't make any grinding noise. That has happened to me several times.
You can braze it back together in a pinch till you get a new spring. I have had it last for a couple of years before it broke again. I keep an extra spring on hand.
check your #'s when you order them because as stated before, they can be wound the wrong way.
mlpankey
Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
Posted: 16 Nov 2010 at 1:40pm |
the bendix spring is broken
CTuckerNWIL
Posted: 16 Nov 2010 at 1:18pm |
Are the teeth missing on the flywheel ring gear where the starter would contact it? The engine will stop in 2 places and these two spots get worn down.
Good
Joined: 05 Apr 2010 Location: Logansport IN Points: 453 |
Posted: 16 Nov 2010 at 10:27am |
Take the nose cone off and it's most likely the torque spring broke or one of the bolts came uscrewed. I've had it happen on a couple tractors of mine. Take the old one with you because they are wound two different ways I get mine at napa for like $14.00. |
B212,716,two 314H's,WC,WD,D19,190XT
jimwithag
Posted: 16 Nov 2010 at 9:50am |
Starter was working a ok, then all the sudden, the next time I went to start the WD, I could hear it spinning, but doesn't engage. I took off started, dah, now what. It's a 12v conversion. Thanks, Jim
Jim Cridge
